Starting GUI from CLI
I want to install Home Assitant on my Raspberry PI3.
  • I have created a SD card with RaspberryImager choosing Home Assistant OS 10.2
  • I inserted the SD card in my RaspberryPI
  • I powered the Raspberry
  • Now I see Home Assistant CLI
  • In the installation description you say: type “http://homeassistant.local:8132” in your desktop’s browser
    Which desktop, which browser??
Any laptop/desktop/ipad and any browser.
The Raspberry doesn’t need a screen and inputs connected. Only network and power.
So to be clear. The HA Raspberry does not display your GUI.
You have to use ANOTHER machine (laptop, phone, tablet) on the same network to enter the GUI.
No, the HA machine does not display your UI. It is a headless operating system setup, meant to be accessed through the network using your phone or laptop.
Is there really no other way to fix this? I want to use my server also as a gui for a wall screen. But i don’t want to use docker etc, because HAOS is very stable…
HA Supervised install is the only way, I know, will get you there. But yes, skills are needed :wink:
then i’ll stick to my plan, leaving my HAOS on the system it’s installed now. And my new nuc will be used as GUI, and other stuff. Thanks!
