Hello, I am getting this error in the logs.
Source: components/recorder/util.py:130
Integration: recorder (documentation, issues)
First occurred: 20.26.45 (1 occurrences)
Last logged: 20.26.45
Error executing query: (sqlite3.DatabaseError) database disk image is malformed [SQL: INSERT INTO recorder_runs (start, "end", closed_incorrect, created) VALUES (?, ?, ?, ?) RETURNING run_id] [parameters: ('2023-10-04 17:26:43.461362', None, 0, '2023-10-04 17:26:45.716141')] (Background on this error at: https://sqlalche.me/e/20/4xp6)
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/engine/base.py", line 1965, in _exec_single_context
self.dialect.do_execute(
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/engine/default.py", line 921, in do_execute
cursor.execute(statement, parameters)
sqlite3.DatabaseError: database disk image is malformed
File "/usr/src/homeassistant/homeassistant/components/recorder/util.py", line 130, in session_scope
yield session
File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 1412, in _setup_run
self.recorder_runs_manager.start(session)
File "/usr/src/homeassistant/homeassistant/components/recorder/table_managers/recorder_runs.py", line 98, in start
session.flush()
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/orm/session.py", line 4179, in flush
self._flush(objects)
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/orm/session.py", line 4314, in _flush
with util.safe_reraise():
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/util/langhelpers.py", line 146, in __exit__
raise exc_value.with_traceback(exc_tb)
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/orm/session.py", line 4275, in _flush
flush_context.execute()
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/orm/unitofwork.py", line 466, in execute
rec.execute(self)
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/orm/unitofwork.py", line 642, in execute
util.preloaded.orm_persistence.save_obj(
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/orm/persistence.py", line 93, in save_obj
_emit_insert_statements(
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/orm/persistence.py", line 1226, in _emit_insert_statements
result = connection.execute(
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/engine/base.py", line 1412, in execute
return meth(
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/sql/elements.py", line 516, in _execute_on_connection
return connection._execute_clauseelement(
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/engine/base.py", line 1635, in _execute_clauseelement
ret = self._execute_context(
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/engine/base.py", line 1844, in _execute_context
return self._exec_single_context(
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/engine/base.py", line 1984, in _exec_single_context
self._handle_dbapi_exception(
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/engine/base.py", line 2339, in _handle_dbapi_exception
raise sqlalchemy_exception.with_traceback(exc_info[2]) from e
sqlalchemy.exc.DatabaseError: (sqlite3.DatabaseError) database disk image is malformed
(Background on this error at: https://sqlalche.me/e/20/4xp6)```
