I have the fordpass integration installed.
This integration provides the entity “sensor.fordpass_fuel”.
This entity has an attribute “DistanceToEmpty”.
The idea is, that rhasspy can tell me, how many kilometers are left in my tank.
The problem is, i can’t access this attribute.
I used this manual:
and this code:
service: mqtt.publish
topic: test/test
payload: "\"{{ state_attr('sensor.fordpass_fuel','DistanceToEmpty') }}\""
When i run the code, the payload is always “None”.
I also tried different entitys with attributes, but it always says “None”.
next try was to create a template-sensor in the configuration.yaml:
sensors:
ford_range:
friendly_name: Ford range
value_template: "{{ sensor.fordpass_fuel.attributes.DistanceToEmpty }}"
i reloaded my configuration, but the new sensor was not displayed anywhere.
Does someone knows a good way to access attributes?
