State attr last trigger with short date
Hi
I’m using this line to display the last date an automation triggers but the outcome is way too long.
{{ state_attr(‘automation.gps_naar_gym_geweest’, ‘last_triggered’) }}
2023-08-08 13:45:22.458774+00:00
I’m only interested in the date (and time till 13:45 the rest can be removed), is that possible?
You can use strftime() to format the output however you like:
{{ (state_attr('automation.gps_naar_gym_geweest', 'last_triggered')|as_local).strftime('%Y-%m-%d %H:%M') }}
If you live somewhere that uses UTC or just want the output to be UTC, you do not need the | as_local .
