Hi, i want to use statistics sensor to generate min/max over a time period. But i can not evaluate the min and max. All help i’ve found point towards attribute value_max and value_min.
But querying this (or old notation max_value) will always return None
- platform: statistics
name: "Kitchen power mean over last 15 minutes"
entity_id: sensor.kuche_shelly25_1_active_power_b
state_characteristic: mean
max_age:
minutes: 15
sampling_size: 100
According to the documentation, value_max and value_min aren’t attributes but the value you assign to the state_characteristic option in order to configure the sensor’s behavior.
In your example, you assigned mean to state_characteristic. Set it to value_max if you want the sensor to report the maximum value.
Because that’s documented as being one of the sensor’s attributes.
That post is two years old. The Statistics integration was modified since then and its documentation was updated to reflect those changes.
I’ve cautioned other users that when searching for answers they should look for recent posts. Given Home Assistant’s constant and rapid evolution, anything over a year old might be outdated
