I’m stuck on creating a for loop that retrieves multiple names from the attributes of a sensor.
If I do the following:
{% for faces in state_attr('image_processing.microsoftface_ip_webcam','faces') %}
{%- if loop.first %} {% elif loop.last %} and {% else %}, {% endif -%}
{{ states.image_processing.microsoftface_ip_webcam.attributes.faces }}
{% endfor %}
I get:
[{'name': 'Carmen', 'confidence': 58.236}, {'name': 'Michiel', 'confidence': 54.443}]
and [{'name': 'Carmen', 'confidence': 58.236}, {'name': 'Michiel', 'confidence': 54.443}]
Which makes sense. But since I want the name I add the .name
to the end:
{{ states.image_processing.microsoftface_ip_webcam.attributes.faces.name }}
{% endfor %}
But then no names are returned:
and
My goal is to have both the names displayed. e.g. Carmen and Michiel
Could someone help me figure out what I’m am doing wrong?
ps I can access the seperate name values {{states.image_processing.microsoftface_ip_webcam.attributes.faces[0].name }}
, but since the list doesn’t always have the same amount of values, I would like to create it dynamically.
