OK I’ve got a Tuya-managed dehumidifier
It identifies itself as a device category KT an air conditioner…makes sense as all you’re doing is getting the fan speed and temp range which in this case will translate into the humidity target set point
# Supported Device Category
| First Class Category | category code | category[en] | HA Core Supported Version | HA Platforms |
| Large Home Appliances | kt | Air conditioner | Release 2021.10 | Climate, Switch, Light |
| Small Home Appliances | cwysj | Pet Water Feeder | Release 2021.10 | Switch |
| | qn | Heater | Release 2021.10 | Climate, Switch, Select, Sensor |
| | sd | Robot Vaccum | Release 2021.11 | Vacuum |
| | fs | Fan | Release 2021.10 | Fan |
| | cl | Curtain | Release 2021.11 | Cover |
| | kj | Air Purifer | Release 2021.10 | Fan, Switch |
| | cs | Dehumidifier | Release 2021.11 | Humidifier |
| | xxj | Diffuser | Release 2021.11 | Switch |
| Electrician Category | kg | Switch | Release 2021.10 | Sensor, Switch, Light, Select |
| | cz | Socket | Release 2021.10 | Sensor, Switch |
| | pc | Power Strip | Release 2021.10 | Sensor, Switch |
| | clkg | Curtain Switch | Release 2021.11 | Cover |
| | jdcljqr | Curtain Robot | Release 2021.11 | Cover |
| | wk | Thermostat | Release 2021.10 | Climate |
| | dlq | Circuit Breaker | Release 2021.10 | Switch |
This file has been truncated. show original
BUT I cannot control or see any of the state attributes for the device. It wont’ even turn on.
I’ve tried removing the dehumidifier from the Tuya IoT cloud, re-adding it, but nothing
It works just fine in SmartLife APP, so the only thing I can come up with is the device attributes aren’t being sent down to Home Assistant from the cloud.
Any ideas? as I’d like to be able to set levels and create an automation routine.
Thanks in advance
