Hi all,
I’m trying to configure 2 HA instances as master/slave. My goal is:
- master will send commands that slave will consume
- slave will send states that master will consume and display in UI
Configuration code used:
#Master conf:
mqtt_eventstream:
publish_topic: ha/commands
subscribe_topic: ha/states
ignore_event:
- state_changed
#Slave conf:
mqtt_eventstream:
publish_topic: ha/states
subscribe_topic: ha/commands
ignore_event:
- call_service
I tried enabling logger for this component but it looks this component is not importing the logging module so nothing relevant is displayed when raising level to debug.
In the slave I can see the state_changed events being generated locally (using Developer).
Using MQTT Explorer I don’t see any event created in the ha/states topic, however I see some in the ha/commands.
Any idea about why state_changed events are not sent to mqtt using eventstream? Has anyone made it work that could share some config example?
Any other troubleshooting suggestion is very welcomed.
Thanks!
