I’m trying to set up an automation that switches on a light when a door is opened, when the alarm is “Armed away”.
The problem is, the act of opening the door changes the alarm state from “Armed Away” to “Pending”, until the user code is input and it changes to “Disarmed”.
So the light doesn’t turn on as I wanted.
This is a real world example of me disarming the alarm with timestamps:
Alarm is Armed away
20:11:43 - 21 hours ago
Door was opened
11:07:15 - 7 hours ago
Alarm changed to Pending
11:07:15 - 7 hours ago (Happens same time as door is opened)
>changed to Disarmed (User code accepted)
11:07:26 - 7 hours ago
A solution I can see is to save only the “Armed Home” and “Disarmed” states (ignoring “Pending”) and use that in the automation.
Would I use a helper for that?
Any help would be appreciated
