Im getting this error
Entity sensor.alpha_read_raw_register_register_address (<class 'homeassistant.components.mqtt.sensor.MqttSensor'>) is using state class 'measurement' which is impossible considering device class ('enum') it is using; expected None; Please update your configuration if your entity is manually configured, otherwise create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+mqtt%22
Im thinking it relates to this code:
- state_class: "measurement"
force_update: "true"
icon: "mdi:information-variant"
name: "Dispatch Normal Response Status"
unique_id: "dispatch_normal_response_status"
state_topic: "HomeAssistant/MQTTSensor/NORMAL_RESPONSE_responseStatus"
value_template: "{{ value | string }}"
device_class: "enum"
Whats the proper way to write this? Thanks!
