SylvainGa
(Sylvain Gagnon)
February 8, 2020, 3:44am
1
Had this in the 0.105 blog entry but with all the replies there, it might have gotten drowned there
This shows switches yellow when on:
entities:
- entity: ...
- entity: ...
- entity: ...
show_name: true
theme: slate
type: glance
show_state: true
state_color: true
But this DOESN’T. Is ’ type: entity-filter
supported for state_color
entities:
- entity: ...
- entity: ...
- entity: ...
state_color: true
show_header_toggle: true
state_filter:
- 'on'
theme: slate
type: entity-filter
Is it by design or something got forgotten?
123
(Taras)
February 8, 2020, 1:34pm
2
I can confirm that I see the same behavior in 0.105: state_color
doesn’t work with entity-filter
I just posted it as an Issue in homeassistant-polymer github repo:
0.105: state_color does not work with entity-filter card
finity
February 9, 2020, 2:30am
3
I guess I’m not sure why before it was instituted as a change that it wasn’t implemented in every card (at least the officially included ones) that could contain “entities:”.
123
(Taras)
February 9, 2020, 12:55pm
4
Here’s the reply I received:
I’ve done the second part (with no revelations) and I thought I was already doing the first part. Has the reply helped anyone else fix the problem?
I simplified my UI’s code down to this and state_color
still has no influence on the icon colors.
cards:
- type: entity-filter
state_color: true
entities:
- binary_sensor.laundry_door_lock
- lock.laundry_door_lock
state_filter:
- "on"
- locked
- unlocked
Where would the suggested “Options for the card … under a nested card
option” go in that example?
EDIT
This works:
entities:
- entity: binary_sensor.laundry_door_lock
state_color: true
However, that seems like a workaround for the issue that state_color
cannot be defined to apply for all entities within a given entity-filter
card.
SylvainGa
(Sylvain Gagnon)
February 9, 2020, 9:03pm
5
Works for me too, thanks.
(Taras)
February 9, 2020, 9:38pm
6
I learned how it’s done (from iantrich). You have add a card:
option and then put the state_color:
option under it.
type: entity-filter
card:
state_color: true
theme: slate
state_filter:
- 'on'
entities:
- entity: ...
- entity: ...
- entity: ...
That will make state_color
apply to each entity in entities
. If you don’t want to apply to all of them, then you need to specify it on per-entity basis (as shown in my previous post).
hasn’t there been word we could also use the state_color option on a per view basis? Its not in the docs on https://www.home-assistant.io/lovelace/views/ but seem to recall that from the discussion before introduction of state_color.
If not, that might be a good FR
