After installing Hass.io 32bit and restoring my snapshot, i have problems with State History off all sensors, switches, Input Selects and the like. Also the History tab won’t load.
The Logbook tab works fine, and also the sensor card in Lovelace.
I’m running Home Assistant 0.80.2.
I had some problems with MariaDB, so i changed the config to use the standard Sqlite-base. I also deleted the old .db and rebooted, but i still have the issue.
I find this in the log file, but i’m not sure if it’s related.
In the UI i only get this if i select a component: Loading state history…
http://HASSIOURL/frontend_latest/f8f40a39e6efb2531bc7.chunk.js:4:29116 Uncaught TypeError: Cannot read property '_leaflet_pos' of undefined
Any help or tips is greatly appreciated, as i’ve done what i can think off. I’d rather not install Hassio all over and restore my config again, as i takes a whole afternoon more or less.
