State of event-based template binary sensor unknown after HA restart
I’d like to get feedback on an issue I have logged.
I believe this is an edge case not catered for with the introduction (standardisation) of allowing unknown states for binary sensors.
I want to be clear that this isn’t an objection against the use of the unknown state – only that there is an edge case where it doesn’t actually make sense (to me).
When using template binary sensor triggered by an event, the sensor will have an unknown state (e.g. after an HA restart) until triggered for the first time. At this point, it may still make sense to allow an unknown state, but once the auto_off option gets specified, it indirectly implies a sensor that’s normally off (by default) and sometimes on (when triggered). Considering this, it would be impossible for the sensor to have any other state.
It would not be an option to perform any kind of artificial triggering, since it may lead to undesired consequences.
Perhaps one option is to introduce an initial_state option to make this explicit (rather than inferring a default state from auto_off).
There doesn’t seem to be any workarounds.
- trigger:
  - platform: event
    # the type below can really be set to any valid event type for the purposes of illustration
    event_type: amcrest
    # the next section can be omitted, but i wanted to include my full config to make the specific issue clear
    event_data:
      event: CallNoAnswered
      payload:
        action: Start
  binary_sensor:
    state: true
    auto_off: 5  # seconds
Documentation: Template - Home Assistant (home-assistant.io)
Issue: State of event-based template binary sensor shouldn’t be unknown after HA restart · Issue #67397 · home-assistant/core (github.com)
A change that mostly improves this has been implemented via Restore state of trigger based template binary sensor by emontnemery · Pull Request #67538 · home-assistant/core · GitHub. State will be restored after a restart. After implementing such a sensor it’s state will be unknown until triggered the first time, but not thereafter.
