Hi all, this is my first post…
I have recently started in the world of ha, I hope you will forgive the silly questions…
I made a simple automation that turns a light on and off. It is triggered by a door sensor. After 6 second, the light go off.
In the same room I also have a courtesy light. My idea was that: if the main light turns on, the courtesy light has to go off, until the main light goes off.
After the main light goes off, the courtesy light turns on (and stays on).
I thought about making a script, to be invoked twice in automation, but there is something wrong.
alias: Luce ingresso
description: ''
- platform: state
entity_id: binary_sensor.door_window_sensor_158d00024de198
to: 'on'
condition:
- condition: time
after: '09:00:00'
before: '23:59:00'
- service: light.turn_on
color_temp: 120
entity_id: light.yeelight_color_0x00000000052c8b8f
- service: script.cornice_ingresso
data: {}
- delay:
hours: 0
minutes: 0
seconds: 6
milliseconds: 0
- service: light.turn_off
data: {}
data: {}
mode: single
The script cornice_ingresso:
alias: Cornice ingresso
sequence:
- choose:
- conditions:
- condition: state
state: 'on'
sequence:
data: {}
entity_id: light.yeelight_stripe_0x0000000004575490
default:
data: {}
mode: single
‘script.cornice_ingresso’ is invoked twice in automation. The first time, right after the main light turns on. The second after it goes out. In my head, the service light should go off in the first case, and light up in the second (the default action). It just doesn’t work well.
The courtesy light goes out, but then, after the main light goes out, it does not turn on again. Where am I doing wrong ?
Thanks for the tips !
