I have several Sengled zigbee bulbs, and after home assistant restarts the states of them don’t match reality. They seem to be set to on and off at random. I have these entities in my recorder section, which I thought would cause their state to be retained across restarts, but that doesn’t seem to help. My home assistant restarts a few times a day due to a zigbee bug.
Does everyone else have this issue with Sengled bulbs? Does anyone have a solution?
I would be interested in the answer to this as well.
I have 4 Sengled bulbs that worked perfectly for a year and then about a month ago (or a little more) two of them started being displayed as ‘on’ after every restart of HA but the light isn’t actually on.
Every light that is actually ‘on’ still displays correctly, tho.
It’s easy enough to click them to turn them ‘off’ to match the real state but I’m not sure what changed to cause the new behavior.
Yeah I’m also using a HUSBZB-1. It wouldn’t be a big deal, but I have to restart the HA because my zigbee network keeps losing connections. I’ll look into that issue separately.
Same issue as well, I usually just toggle them if I remember to, but they usually fall into their groove after some automations. Eventually I’ll get rid of the Zigbee stuff as the consolidation continues, rid myself of the maddening SmartThings MQTT bridge, a couple Zwave switches, etc.
