State of the Insteon component?
I am currently using the insteon-mqtt project but I just saw that a “new” insteon component for HA exist. I played in the past with other Insteon component for HA but they had many troubles. This is the reason I started using insteon-mqtt.
I have a couple of question about the new insteon component :
1- I have a USB modem and I was wondering if the new component need to poll the modem/devices to get state change or only listen for incoming messages?
2 - Does it support all the button of the KeypadLinc? I was not able to find confirmation for that.
3 - Does it support I/OLinc?
Thanks a lot,
Hope that helps.
For me, both entities are showing as switches.
Using ISY/plm and latest Hassio.
Any thoughts?
My reply in this tread was only related to the Insteon component, not the ISY component that you are using.
The current release HA0.102.3 Insteon integration and all releases since .096.5 fail with unable to connect to 2245 message within an hour of reboot. I have set up a new pi running 0.96.5 and it is still working after 3 days.
HA 0.96.5 also gets unable to connect to 2245 but a second try reestablishes the connection.
Logs below showing this happen. Any ideas on how to fix this?
019-12-06 23:54:20 WARNING (MainThread) [insteonplm.plm] Lost connection to Insteon Modem: True
2019-12-06 23:59:01 ERROR (MainThread) [insteonplm] Reconnect to Hub (TimeoutError)
2019-12-06 23:59:01 WARNING (MainThread) [insteonplm.plm] Lost connection to Insteon Modem: True
2019-12-07 00:01:57 ERROR (MainThread) [insteonplm] Reconnect to Hub (TimeoutError)
2019-12-07 00:01:57 WARNING (MainThread) [insteonplm.plm] Lost connection to Insteon Modem: True
2019-12-07 00:16:40 ERROR (MainThread) [insteonplm] Reconnect to Hub (TimeoutError)
2019-12-07 00:16:40 WARNING (MainThread) [insteonplm.plm] Lost connection to Insteon Modem: True
2019-12-07 00:30:44 ERROR (MainThread) [insteonplm] Reconnect to Hub (TimeoutError)
2019-12-07 00:30:44 WARNING (MainThread) [insteonplm.plm] Lost connection to Insteon Modem: True
2019-12-07 00:31:56 ERROR (MainThread) [insteonplm] Reconnect to Hub (TimeoutError)
2019-12-07 00:31:56 WARNING (MainThread) [insteonplm.plm] Lost connection to Insteon Modem: True
2019-12-07 07:11:48 ERROR (MainThread) [insteonplm] Reconnect to Hub (TimeoutError)
2019-12-07 07:11:48 WARNING (MainThread) [insteonplm.plm] Lost connection to Insteon Modem: True
2019-12-07 08:11:57 ERROR (MainThread) [insteonplm] Reconnect to Hub (TimeoutError)
2019-12-07 08:11:57 WARNING (MainThread) [insteonplm.plm] Lost connection to Insteon Modem: True
2019-12-07 09:13:18 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.171
2019-12-07 09:47:28 WARNING (MainThread) [insteonplm.devices] Device 3D.FA.FE returned a pre-NAK message
2019-12-07 09:47:28 WARNING (MainThread) [insteonplm.devices] Checking status to confirm if message was processed
2019-12-07 09:48:05 WARNING (MainThread) [insteonplm.devices] Device 3D.FA.FE returned a pre-NAK message
2019-12-07 09:48:05 WARNING (MainThread) [insteonplm.devices] Checking status to confirm if message was processed
There is an update to the hub connection issue in the beta release of 0.105 if you can test that. It should be in the main release of 0105.0 this week.
FYI, there is an updated version of the Insteon component available as a custom component for beta testing. Details about it are in this post:
