TLDR;
I am displaying a camera still picture with an picture-entity and I want to display the state of an entity on the right lower end of the picture. Currently the state of the camera is displayed which is useless.
In other words: I want to merge both lines.
------ Details ------
Hello everyone,
I have an Husqvarna Automower and integrated it with the following HACS plugin: https://github.com/walthowd/ha-automower This integration provides
- a device tracker
- a vacuum instance
following the entities state:
device_tracker.automower_h_xxx home source_type: gps
latitude: XXX
longitude: XXX
gps_accuracy: 0
status: Parked manually
icon: mdi:sleep
vendor: Husqvarna
model: Automower 450X
friendly_name: Miki
vacuum.miki Parked manually status: Parked manually
battery_level: 0
battery_icon: mdi:battery-alert
connected: false
nextStartSource: NO_SOURCE
operatingMode: AUTO
showAsDisconnected: false
storedTimestamp: 2020-04-07T14:53:35.931000
friendly_name: Miki
icon: mdi:sleep
supported_features: 223
Then I created a camera (followed https://www.home-assistant.io/cookbook/google_maps_card/) like
camera:
- platform: generic
still_image_url: https://maps.googleapis.com/maps/api/staticmap?center={{ states.device_tracker.automower.attributes.latitude }},{{ states.device_tracker.automower.attributes.longitude }}&zoom=19&size=500x500&maptype=satellite&markers=color:blue%7Clabel:P%7C{{ states.device_tracker.automower.attributes.latitude }},{{ states.device_tracker.automower.attributes.longitude }}&key=YOURAPIKEY
limit_refetch_to_url_change: true
this results to the following entity state:
camera.miki idle access_token: xxx
friendly_name: Miki
entity_picture: /api/camera_proxy/camera.miki?token=xxx
supported_features: 0
and included a picture entity on my gui
- type: picture-entity
entity: camera.miki
camera_view: live
As you can see on https://www.home-assistant.io/lovelace/picture-entity/ the picture is displayed with the name and the state of the entity in the bottom. In my case it displays “Miki” as the name and “Untätig” which is just the german translation for “idle”. But I don’t want to display the state of the camera, instead I want to display the status attribute of the device tracker or the state of the vauum entity.
How can I do this? I tried to make a template sensor feed by the camera and the vacuum entity and display it with the picture-entity, but this didn’t work.
Thanks for your help!
Kind regards, Christian
