State should be persisted accross restart
If a state need to be unknow, the user just need to set that to unknown at restart. This is what I do on homeseer and it should be like that by default here too. In fact that is stopping me from transferring my setup to ha!!
@balloob
  1. Do not tag people like that. It is considered demanding and rude. See: https://community.home-assistant.io/t/how-to-help-us-help-you-or-how-to-ask-a-good-question/114371/1#onesix-should-i-tag-people-22
  2. If you give a specific example we may be able to help.
Ok seems like this is considering offending…
Yes I am asking someone for help ( and takes into account athat a lot on people have asked for it) what is the issue ?
Would creating an issue on github be considered less offending?
This is a community, as a community member as ask for a change. So i use the forum to psss that message.
The issue is that it is rude and demanding. Don’t do it.
If you have a question, just ask it without tagging people. Particularly without tagging the project founder.
An issue may be appropriate, if it is actually an issue. Otherwise a feature request may be appropriate. Or it may be that you are just misunderstanding something, in which case we can help.
Explain your actual issue here, with a specific example.
Man , this is crazy, just delete my posts,
Is that a sort of a sect (can’t tag the founder)?
No it is just politeness. Generally don’t tag anyone, unless you are thanking them, as per the FAQ I linked you to. You should read it all.
Do you want me to delete this topic or do you want some help?
If you want help:
There are many knowledgeable people here that may be able to help you. No need to tag the project founder.
Be polite, be specific.
