State stopped updating, but history works
The state of this entity, including its last update time, is stuck:
As you can see the history graph has more recent values and they fit with the values I see in the zigbee2mqtt log (timestamps are shifted by 1 hour in this log):
info  2023-01-21 16:43:48: MQTT publish: topic 'zigbee2mqtt/Aqara T/H Freezer', payload '{"battery":57,"humidity":52.48,"linkquality":94,"power_outage_count":31,"pressure":1025.1,"temperature":-9.49,"voltage":2935}'
info  2023-01-21 16:46:51: MQTT publish: topic 'zigbee2mqtt/Aqara T/H Freezer', payload '{"battery":57,"humidity":52.48,"linkquality":102,"power_outage_count":31,"pressure":1025.1,"temperature":-9.64,"voltage":2935}'
info  2023-01-21 16:46:51: MQTT publish: topic 'zigbee2mqtt/Aqara T/H Freezer', payload '{"battery":57,"humidity":52.14,"linkquality":102,"power_outage_count":31,"pressure":1025.1,"temperature":-9.64,"voltage":2935}'
info  2023-01-21 16:46:51: MQTT publish: topic 'zigbee2mqtt/Aqara T/H Freezer', payload '{"battery":57,"humidity":52.14,"linkquality":105,"power_outage_count":31,"pressure":1024.8,"temperature":-9.64,"voltage":2935}'
info  2023-01-21 16:47:21: MQTT publish: topic 'zigbee2mqtt/Aqara T/H Freezer', payload '{"battery":57,"humidity":52.14,"linkquality":102,"power_outage_count":31,"pressure":1024.8,"temperature":-9.61,"voltage":2935}'
info  2023-01-21 16:47:21: MQTT publish: topic 'zigbee2mqtt/Aqara T/H Freezer', payload '{"battery":57,"humidity":52.12,"linkquality":102,"power_outage_count":31,"pressure":1024.8,"temperature":-9.61,"voltage":2935}'
info  2023-01-21 16:47:21: MQTT publish: topic 'zigbee2mqtt/Aqara T/H Freezer', payload '{"battery":57,"humidity":52.12,"linkquality":102,"power_outage_count":31,"pressure":1025.1,"temperature":-9.61,"voltage":2935}'
I’m using zigbee2mqtt and the MQTT integration with auto-discovery.
