HI,
i have 2 identical automations differing only in the trigger section for the sun related events (and some state() style notational changes that are of no consequence here):
one on my Hassos Pi using state sun.sun:
- alias: Sun based theme change
id: 'Sun based theme change'
initial_state: 'on'
- platform: homeassistant
event: start
- platform: state
entity_id: input_select.set_sunset_theme
- platform: state
entity_id: input_select.set_sunrise_theme
# - platform: sun
# event: sunrise
# - platform: sun
# event: sunset
- platform: state
entity_id: sun.sun
to: above_horizon
- platform: state
entity_id: sun.sun
to: below_horizon
condition: []
- service_template: frontend.set_theme
data_template:
{{ states.sensor.sun_based_theme.state }}
- condition: state
entity_id: input_boolean.notify_notify
state: 'on'
- service: notify.notify
data_template:
message: >
Hassos - It is {{ as_timestamp(now()) | timestamp_custom("%X") }},
Sun is {{states.sun.sun.state}} and Frontend is set to
'{{ states.sensor.sun_based_theme.state }}'
and one on my Hassio P using event sunrise/sunset:
initial_state: 'on'
event: start
- platform: state
- platform: state
- platform: sun
event: sunrise
- platform: sun
event: sunset
# - platform: state
# entity_id: sun.sun
# to: above_horizon
# - platform: state
# to: below_horizon
condition: []
data_template:
{{ states('sensor.sun_based_theme') }}
- condition: template
value_template: >
{{ is_state('input_boolean.notify_notify', 'on')}}
data_template:
message: >
Hassio - It is {{ as_timestamp(now()) | timestamp_custom("%X") }},
Sun is {{states('sun.sun')}} and Frontend is set to
'{{ states('sensor.sun_based_theme') }}'
The Hassos triggers correctly, while the Hassio triggers 2 shortly after another, and with the wrong outcome in the first call…
It should be doing it correctly though, because on the same Hassio, i have this autmation working just fine, proving it reads the components sun and its attributes alright. Events though Sunset and sunrise are not reliable for this?
automation:
- alias: Send notification when sun changes state
id: 'Send notification when sun changes state'
platform: state
entity_id: sun.sun
condition:
value_template: >
{{ trigger.to_state.state is in ['above_horizon', 'below_horizon'] and
trigger.to_state.state != trigger.from_state.state }}
value_template: >
data_template:
message: >
Sun state change - {{as_timestamp(now()) | timestamp_custom("%X") }} The Sun is
{{'up' if is_state('sun.sun','above_horizon') else 'down'}}
Is there an explanation for that?
