It will trigger both on state changes, obviously, but also on attribute changes.
Although it’s documented, it’s probably not what the default should be.
The “workaround” is also documented: add any of “to/from/not_to/not_from”, even with an empty value.
It will also trigger on “unavailable/unknown” states.
Although technically logical, you probably don’t want any of your automations (besides technical ones) to trigger on an hiccup.
A workaround is to write something like
which is cumbersome, or to code lengthy templates, which not the most efficient, anyway. I don’t even consider UI, here.
Both also makes so that you cannot trigger only on any attribute changes of “real” values.
Not the most obvious when the expected result for a newcomer would just be: I want a trigger when my binary sensor goes from “on” to “off” and vice-versa
My suggestion would be to add a switch to the state platform trigger to only consider “value” state changes, e.g.
- platform: state
entity_id: sensor.foobar
real_state_only: true
that would ignore “unavailable/unknown” when considering the state change.
(Disclaimer: I haven’t tested this particular combination I’m about to propose since I don’t trigger on attribute changes. However the condition definitely works)
- condition: template
value_template: "{{ trigger.from_state.state not in ['unknown', 'unavailable'] }}"
when your trigger is set to this
- platform: state
accomplish what you need?
I’m not 100% sure whether the trigger.from_state.state will be captured without a from in your trigger though.
Technically, it should then allow you to trigger on attribute changes, but only on “real” states.
That works (although already quite verbose and not newcomers-friendly) if you have only one trigger (or only state ones), but becomes cumbersome (again) if you have multiple, including non-state ones.
Question is not really “can we do it?”. Us, veterans, know we can, but how to do it in a straightforward way, both to be newbie friendly, and to avoid walls of repetitive code
One of the problem is that you do, willingly or not, if you don’t add code to the trigger…
for the record, this functionality is provided. just add
to:
to the trigger, and it will only trigger on state changes and not on attributes changes.
quoting the docs:
If you want to trigger on all state changes, but not on attribute changes, you can to to null (this would also work by setting from, not_from, or not_to to null):
automation:
triggers:
- trigger: state
entity_id: vacuum.test
to:
