State update nor working by ShellyforHASS and Shelly APP
I have just installing my new little shellies but not working very fine.
Shelly Dimmer 2
I have a normal togle switch UP and DOWN
On the app Button type is Edge mode
Not connected to Cloud
When i press on Switch UP light goes UP but on the app it dont update the state. It says OFF. i must then on the app click twice to turn off the light.
This is also when the Light is turned ON and i wlll turn off the light via Switch DOWN.
Wherever the state wil not be updated.
  • Installed ShellyForHASS
    It found the shelly and added as integration, but i can’t turn on turn off via hass. the state is constant on OFF state on HASS.
How can i solve my problem?
Is MQTT maybe o solution but which MQTT commands code should i to use for the shelly’s ?
Should Tasmota maybe solve my problem and can i then also use Regular Switch button also to turn on/off by every click
Check the firmware version of your Shelly devices. There is an issue with ShellyForHass and v1.8.
I use mqtt, work fine.
light:
- platform: mqtt
  schema: template
  state_topic: "shellies/shellydimmer2-xxxx/light/0/status"
  state_template: '{% if value_json.ison %} on {% else %} off {% endif %}'
  command_topic: "shellies/shellydimmer2-xxxx/light/0/set"
  command_on_template: '{"turn": "on"{% if brightness is defined %}, "brightness": {{(brightness | float * 0.3882 + 1) | round(0)}}{% endif %}}'
  command_off_template: '{"turn": "off"}'
  brightness_template: '{{ (value_json.brightness | float * 2.55) | round(0) }}'
