In reference to the slider example for controlling temperature here:
- alias: Temp slider moved
platform: state
entity_id: input_number.target_temp
service: mqtt.publish
topic: 'Heater/cmd/TempDesired'
retain: true
payload: "{{ states('input_number.target_temp') | int }}"
{{ states(‘input_number.target_temp’) | int }} is being published as a string literal which the MQTT subs don’t know what to do with.
If I change it to a hardcoded **payload: 9** then it works as intended. For some reason I can’t get the state of the input_number in the recommended way.
The output of any template is always a string value.
You’ve demonstrated that a non-templated value can maintain its type. In this case, the type is an integer. In contrast, the type of whatever is generated by a template is always a string.
Thanks @Taras. It seems that this line, lifted directly from the documentation example, is meant to render the state of input_number.target_temp as an | int and then publish that to the MQTT topic.
It is literally publishing {{ states(‘input_number.target_temp’) | int }} which breaks the system as the subsciber is expecting an integer.
I’ve pretty much just done what is in the example but it doesn’t behave as expected.
input_number:
target_temp:
min: 8
max: 24
step: 1
unit_of_measurement: °C
icon: mdi:thermometer
automation:
- alias: Set temp slider
platform: mqtt
topic: 'heater/sts/TempDesired'
service: input_number.set_value
value: "{{ trigger.payload }}"
# This second automation script runs when the target temperature slider is moved.
platform: state
topic: 'heater/cmd/TempDesired'
retain: true
# payload: 9
I think I now understand the problem. Are you using version 0.115.X? If you are not, you must use data_template: and not data: in the line after service:.
I believe the examples in the documentation may have been updated to reflect the deprecation of data_template: now that data: serves the same purpose in 0.115 (I.e. data: supports templates). However it becomes misleading for users of older versions where data: doesn’t support the use of templates.
Glad to hear it. Please consider marking my post (above) with the Solution tag. It will automatically place a check-mark next to the topic’s title which signals to other users that this topic has an accepted solution. This helps other users find answers to similar questions.
