FerronN
(Ferron N)
1
Hi all,
I want to get a state attribute based on a variable (for example hard coded) with the entity_id.
{{ state_attr('switch.shellyplug_1', 'last_changed') }}
{{ states.switch.shellyplug_1.last_changed }}
The states
function return the value, but state_attr
not. I’m I doing something wrong?
UPDATE:
Okay I’ve read last_changed
is a property and not an attribute. What is the difference between states and state_attr - #6 by tom_l
How can I use a variable in this line then?
123
(Taras)
2
last_changed
isn’t an attribute so that’s why you can’t use state_attr
to get its value.
It’s a property of the entity’s state
object so if you want its value you reference it like you did in the second template you posted.
FerronN
(Ferron N)
3
I see, I’ve updated my question.
123
(Taras)
4
What do you mean by “use a variable in this line”?
Do you want the template to accept the entity_id as a variable?
Example:
{% set x = 'switch.shellyplug_1' %}
{{ states[x].last_changed }}
FerronN
(Ferron N)
5
Yes, I was just going this direction. Thank you!
