i want to move my installation to a SSD based Raspberry Pi4.
It works well and boot from SSD but the trick with the config File via USB Stick to provide a static IP Address doesnt work.
Are the a other way to change thew IP Address from DHCP to static ?
Best way, in my opinion, is to not do that on the device itself in the first place. Centralized in your router is easier to track and less likely to cause trouble. Isn’t that an option for you as well?
Setting in on router would be my suggestion, too…
But if you want to do it on RPi you could edit the /etc/dhcpcd.conf and add something like this to it:
