Hi, I tryed to find an answer and I found many but none it’s working nor solve my problem (so I think I have some problem searching).
I want to install the DHCP add-on on hass.io on a rpi4 and use it for my whole lan so I tryed to give it a static ip.
I found very old posts, I found posts about using a cli command “nmcli” but the terminal respond with a “command not found”, I found posts talking about editing a file in /etc/NetworkManager but I didn’t see that folder.
Too many posts and not a single solution I can apply.
I’m pretty sure I’m missing something quite obvious so here I am asking for advices.
Go the the Home Assistant web page. Click on the Getting Started sub-tab at the top. Scroll down to the Installation paragraph. Step four explains the process and has links to my-network examples.
I had to build HassOS some time ago to solve issues I had. So I searched the repo and read all docs
Didn’t know that it was linked in the getting started page! Thanks @micque
