Static number send with Action -node
I try to send static value to change my Fully Kiosk brighness. I try couple of different solutions, but Fully Kiosk value not change, Node-red not giving any errors.
The action should be number.set_value not input_number.set_value. If you look at the name of the entity it starts with number.xyz an input number starts with input_number.xyz
Thanks for answer, that fix this problem :slight_smile:
