I love the new energy dashboard. My only problem is that the days are not comparable on the first look. The scale for consumption is different each day and depends on the energy usage.For me it would make sense to have a parameter or something to set a fixed max value for every day.
Wow, I would have assumed that this is fixed already. Is there a way to use fix values?
Greets
I have exactly the same requirement, but unfortunately can’t find any parameter or such. Or is it “only” undocumented?
I would suggest, in month view you can compare each day. so for me a date picker like in history would make sense. the scale would be still dynamic but you could choose the range and have a uniform comparison in the set time range.
