Statistics Graph Card Not summing two sensors
Hi , I am having a challenge with the Statistics Card’s - if I display 2 sensors on a single graph and tick the SUM function it does not show
Not sure if this helps, but sum is adding the measurements for each individual sensor. It does NOT add the values of multiple sensors.
EDIT: As this is about power, there is no sum recorded, as it wouldn’t make sense, hence the sum is not shown.
You could however create a template sensor, to calculate the sum yourself and use this in your graph.
Thanks for the info , will have to lookup how to create a Template Sensor
you can use Helper (min/max)
