Statistics-graph does not recognize any REST sensor statistics
I have a REST sensor that delivers data, these are processed in the statistics.
That works
However, “No statistics found” is displayed in the statistics-graph card.
/config/sensors.yaml
- platform: rest
  username: "admin"
  password: "admin"
  resource: http://singleb.....
  method: GET
  scan_interval: 60
- platform: statistics
  entity_id: sensor.zaehler_kg3cum
/config/customize.yaml
sensor.zaehler_kg3cur:
  state_class: total_increasing
  device_class: energy
  unit_of_measurement: Wh
  last_reset: '1970-01-01T00:00:00+00:00'
sensor.statistik11:
  state_class: measurement
I have been working on this problem for 5 hours thanks for your support in advance.
If you are using Home Assistant 2021.9.x, last_reset: is no longer a valid attribute. Remove it from your customizations.
For energy sensors change the state class to total_increasing.
Thank you for the support (core-2021.9.3)
  1. Change
sensor.statistics11:
  1. restart HASS
  2. Clear browser memory
Unfortunately no change
I made a really stupid mistake. /config/customize.yaml was not involved
