I have an outside temperature sensor. It reads values every 30 seconds (which might be important or not). I’ve made a sensor using statistics integration to show avarage (mean) temperature from last 12h.
It completelly doesn’t work as expected. Let’s say that minimum recorded temperature from last 12h was 7 degress, maximum was 12,5 and current is 8,5. Avarage from last 12h is currenly 10,8 and even tho current temp. (8,5) is LOWER than avarage (10,8) from last 12h this avarage temperature keeps RISING! Maybe I’m not the best in math but this doesn’t make any sense. If current temp. is lower than avarage then avarage should be FALLING. Here’s my config:
sensor outside_avarage_temperature_over_last_12h:
- platform: statistics
name: "Outside avarage temperature over last 12h"
entity_id: sensor.outdoor_temperature
state_characteristic: mean
precision: 1
sampling_size: 1440
max_age:
hours: 12
What am I doing wrong or what do I don’t understand how this integration works?
