Statistics Sensor not showing up
Running HASS 0.95.4. Tried setting up the statistics sensor (https://www.home-assistant.io/components/statistics/) and it does not show up at all.
My configuration.yaml files has these entries:
recorder:
sensor: !include myconfigs/sensors.yaml
myconfigs/sensors.yaml contains this (along with other working sensors):
- platform: statistics
  entity_id: sensor.acurite_5_in_1_wind_speed_mph
  entity_id: sensor.acurite_5_in_1_wind_direction
both of those entities exist. Can someone tell me what I am doing wrong?
Do you mean that the statistics sensor does not show up or that it is not existing (in the dev pane)
http://hassio.local:8123/dev-state
I do not see it when I search for statistics in the states page. I’m assuming that it would show up like any other device there. Is that incorrect?
They won’t be in a statistics Domain - they are a sensor.
What will they be called. Can you tell me why looking at the information I posted above?
In don’t use these myself (yet). From some examples, I guess the sensors have a _mean suffix. So in your case, you should see:
sensor.acurite_5_in_1_wind_speed_mph_mean
sensor.acurite_5_in_1_wind_direction_mean
Nope. The only thing I have with mph in the name is the original ‘sensor.acurite_5_in_1_wind_speed_mph’
I found it. It has an unexpected (to me) name of sensor.stats_mean and sensor.stats_mean_2 … Thanks for the help
I wasn’t aware of this at first, but the documentation was clear on this:
name
(string)(Optional)Name of the sensor to use in the frontend.
Default value: Stats
You could change the name of the sensors like this:
  name: "Acurite 5 in 1 Wind Speed MPH"
  name: "Acurite 5 in 1 Wind Direction"
This will give you the sensors
In which kind of map do you represent the result?
Find nothing that looks like the example.
