Is it possible to show the state (on/off) for computers/consoles/routers etc that are always home?
Not really useful to show Home/Not Home for these devices.
Did you try the “value_template” - https://home-assistant.io/components/sensor.template/
switches:
computer:
value_template: "{% if is_state('switch.wol', 'on') %}on{% else %}off{% endif %}"
turn_on:
service: switch.turn_on
entity_id: switch.wol
turn_off:
service: switch.turn_off
entity_id: switch.pc
I was just reading about it right now via this post
However unless I am missing something it will just always be home because it has detected that it is connected to my router. So just changing the text to be on/off wouldn’t be enough… I’m thinking that i need to see if it is actually on or off (ping maybe). I think that is the link that i am missing…
Yes, I’m using the ping component to check if a machine is up and running or not.
I don’t think you need that - at least I don’t…
So what I mean is, if you base it on your known devices, you can see which devices are home/not home. What that really means is not their physical location but whether or not they are connected to your router. And if they are not connected (so showing not home) then they are off. No need to add a ping to that…
So simple! Thats what i was missing. Thanks
DDK, I turned discovery off so i needed ping.
So… the states were changing but I was still unable to change the name of the states.
I have tried through ping and discovery but neither work so i have obviously still done something wrong.
This in my config file if someone could point out my mistake.
Found some errors and fixed them. I no longer get any errors with below config but still not changing the state name.
homeassistant:
# Name of the location where Home Assistant is running
# Location required to calculate the time the sun rises and sets
latitude: -33.9152560
longitude: 151.1156200
# Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 3
# metric for Metric, imperial for Imperial
unit_system: metric
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: Australia/Sydney
customize:
# Add an entry for each entity that you want to overwrite.
device_tracker.tab_s:
friendly_name: Garys Android Tab 'S'
icon: mdi:tablet-android
device_tracker.garys_iphone:
friendly_name: Garys iPhone
icon: mdi:cellphone-iphone
device_tracker.ryansiphone:
friendly_name: Ryans iPhone
device_tracker.htpc:
friendly_name: HTPC
icon: mdi:movie-roll
device_tracker.nas:
friendly_name: QNAP
icon: mdi:harddisk
device_tracker.xboxsystemos:
friendly_name: xBox One
icon: mdi:xbox
device_tracker.lounge_room_light:
friendly_name: Lounge Room Light
icon: mdi:lightbulb-on-outline
device_tracker.PS4:
friendly_name: PS4
icon: mdi:playstation
# Show links to resources in log and frontend
# introduction:
# Enables the frontend
frontend:
# Enables configuration UI
config:
http:
# Uncomment this to add a password (recommended!)
api_password: !secret api_password
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# base_url: example.duckdns.org:8123
# Checks for available updates
# Note: This component will send some information about your system to
# the developers to assist with development of Home Assistant.
# For more information, please see:
# https://home-assistant.io/blog/2016/10/25/explaining-the-updater/
updater:
# Optional, allows Home Assistant developers to focus on popular components.
include_used_components: true
# Discover some devices automatically
#discovery:
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time
history:
# View all events in a logbook
#logbook:
# Track the sun
sun:
# Logger
#logger:
# Yeelight - Lounge Room
light:
- platform: yeelight
devices:
10.10.0.12:
transition: 1000
use_music_mode: True
save_on_change: True
# 192.168.1.13:
# name: Front Door
# Netgear Router R7000 NightHawk
device_tracker:
- platform: netgear
username: !secret netgear_un
password: !secret netgear_password
interval_seconds: 10
consider_home: 0:03:00
track_new_devices: yes
- platform: ping
hosts:
HTPC: !secret htpc_ip
Laptop: !secret laptop_ip
# Weather prediction and QNAP
sensors:
playstation_sensor:
value_template: '{% if is_state("device_tracker.ps4", "home") %}online{% else %}offline{% endif %}'
xbox_sensor:
value_template: '{% if is_state("device_tracker.xboxsystemos", "home") %}online{% else %}offline{% endif %}'
- platform: yr
- platform: moon
- platform: qnap
host: !secret qnap_ip
username: !secret qnap_un
password: !secret qnap_password
timeout: 30
monitored_conditions:
- status
- cpu_usage
- memory_percent_used
- volume_percentage_used
- network_tx
# Text to speech
tts:
- platform: google
group: !include groups.yaml
Solved it. For anyone new and wondering the same thing setting up the template means that you need to call it a different way… replace
- device_tracker.xboxsystemos
with
- sensor.xbox_sensor
or whatever you have called the new sensor. It obviously was not updating for me as i was looking at the wrong component… duh…
Notice the known device device_tracker.kyloren in the code I sent you. So no it will not be allways home.
