Hello, in my attempts to display the status of the washer and dryer, I run into the problem that it only succeeds with one. depending on which one is on top. The status is not displayed correctly for one of them. Do I need to arrange the config differently? Here’s my config:
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
frontend:
themes: !include_dir_merge_named themes
# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
sensors:
# Trockner
trockner_watts:
value_template: '{{ states.switch.trockner.attributes["current_power_w"] | float }}'
unit_of_measurement: 'w'
trockner_total_kwh:
value_template: '{{ states.switch.trockner.attributes["total_consumption"] | float }}'
unit_of_measurement: 'kwh'
trockner_temperature:
value_template: '{{ states.switch.trockner.attributes["temperature"] | float }}'
unit_of_measurement: '°C'
# Waschmaschine
waschmaschine_watts:
value_template: '{{ states.switch.waschmaschine.attributes["current_power_w"] | float }}'
waschmaschine_total_kwh:
value_template: '{{ states.switch.waschmaschine.attributes["total_consumption"] | float }}'
waschmaschine_temperature:
value_template: '{{ states.switch.waschmaschine.attributes["temperature"] | float }}'
# Aquarium Gaesteklo
aquarium_watts:
value_template: '{{ states.switch.aquarium_gasteklo.attributes["current_power_w"] | float }}'
aquarium_total_kwh:
value_template: '{{ states.switch.aquarium_gasteklo.attributes["total_consumption"] | float }}'
aquarium_temperature:
value_template: '{{ states.switch.aquarium_gasteklo.attributes["temperature"] | float }}'
# Trockner eigener Sensor
dryer_status:
entity_id:
- input_select.dryer_status
value_template: '{{ states.input_select.dryer_status.state}}'
# Waschmaschine eigener Sensor
washing_machine_status:
entity_id:
- input_select.washing_machine_status
value_template: '{{ states.input_select.washing_machine_status.state}}'
# Eingabemöglichkeiten Trockner
input_select:
dryer_status:
options:
- aus
- arbeitet
- fertig
initial: aus
# Eingabemöglichkeiten Waschmaschine
input_select:
options:
- aus
- arbeitet
- fertig
initial: aus
and the automation:
## Waschmaschine arbeitet
- id: '1122334455018'
alias: Waschmaschine arbeitet
description: Wenn Steckdose über 10 Watt verbraucht, wird Zustand des Sensors Waschmaschine
auf "arbeitet" gesetzt.
- above: '10'
entity_id: sensor.waschmaschine_watts
for: 00:00:30
platform: numeric_state
condition: []
- data:
option: arbeitet
entity_id: input_select.washing_machine_status
service: input_select.select_option
mode: single
## Waschmaschine fertig
- id: '1122334455019'
alias: Waschmaschine fertig
description: ''
- above: '0.5'
below: '7'
for: 00:01:30
condition:
- condition: state
state: arbeitet
- data:
option: fertig
- data:
message: Die Waschmaschine ist fertig und möchte ausgeräumt werden!
service: notify.mobile_app_in2023
- data:
service: notify.mobile_app_oneplus_a6013
mode: single
##Waschmaschine aus
- id: '1122334455020'
alias: Waschmaschine aus
description: ''
- below: '0.5'
for: 00:00:30
condition: []
- data:
option: aus
## Trockner arbeitet
- id: '1122334455021'
alias: Trockner arbeitet
description: Wenn Steckdose über 10 Watt verbraucht, wird Zustand des Sensors Trockner
- above: '10'
entity_id: sensor.trockner_watts
for: 00:00:30
condition: []
- data:
option: arbeitet
entity_id: input_select.dryer_status
mode: single
## Trockner fertig
- id: '1122334455022'
alias: Trockner fertig
description: ''
- above: '0.5'
below: '7'
for: 00:01:30
condition:
- condition: state
state: arbeitet
- data:
option: fertig
- data:
message: Der Trockner ist fertig und möchte ausgeräumt werden!
- data:
mode: single
##Trockner aus
- id: '1122334455023'
alias: Trockner aus
description: ''
- below: '2'
for: 00:00:30
condition: []
- data:
option: aus
The result is:
(First status = correct, second = not available)
