Status Smart Bulbs UK
Has anybody in the UK used these bulbs with HA https://www.statussmart.com/ ??
I’m working on the assumption that these bulbs are simply something else rebadged, but how would I go about finding what the underlying system actually is without any manufacturers information. TIA.
I have one of these bulbs too. I was hoping home assistant would be able to detect it, but no dice. I hope someone figures out how!
I didn’t buy the bulbs in the end. Have you got yours working with the statussmart app?
Yes, they work fine in the statussmart app, but not with Home assistant. Home assistant found a tuya device which I think might work. I’ll try set up the bulb in the tuya app, but this means resetting the bulbs which is a bit of a hassle. I’ll try this week and make a post on this thread if it works!
You may (or may not) be able to use Tuya Convert (Tuya Convert - Tasmota) to convert the bulbs into a format more readily recognised by HA.
I can confirm that these work with HA if you add them with the Tuya Smart app and not the Status Smart app. Then the Tuya integration just finds it.
