SteadyRoom: stop a mini-split from short cycling by controlling it from a room sensor
Most split units measure the temperature at their own air intake, high up on the wall. When heating, they believe the room has reached the target long before the sofa has, throttle down, switch off and start again a few minutes later.
I had been working around this with one automation and nine helpers per room. SteadyRoom is that logic as an integration: free, open source (MIT), and in the Marketplace since 17 November (search for SteadyRoom, or use HACS on 2026.10).
What it does:
  • One virtual thermostat per room. You pick the air conditioner and a temperature sensor in the room; everything else has defaults.
  • Heat, cool or off is decided from the room sensor.
  • The unit receives its own measured temperature plus an offset as its setpoint, so it sees a clear demand whatever its sensor error is. The offset grows with the distance to the target.
  • Just past the target the unit is really switched off (0.2 K by default) and comes back on 0.2 K below it.
  • Auto mode with a lock before the opposite direction, door and window contacts, a schedule helper, and a test run in which it only shows what it would send.
It is lean by design: it does this one job.
Status: at my place it runs two rooms with Panasonic units (Panasonic Comfort Cloud). Other brands are untested; they should work if the climate entity reports the unit’s own temperature. Celsius only, Home Assistant 2026.10 or newer.
I would like to hear how it behaves with other brands and what you would change in the control logic.
