My Stelpro STZW402+ thermostat suddenly started working at full blast this morning at 4:54 AM
There is nothing in the HomeAsistant logs about it.
I am running version 2021.5.5 on raspberry pi 4 in python venv. The USB Z-wave stick is Nortek combine z-wave and zigbee, I have a few of these thermostat and several sensors.
I switched to running Home Assistant Operating System on the same raspberry pi, the issue didn’t happen again since. But I created an automation rule just in case to check if temperature on any of the thermostat is switched to higher then 25C and send me notification and switch back to reasonable value.
