Anyone played with those ? I should receive them shortly and want to integrate them in HA (automation, hadashboard + - temp and also in the web interface). They are line voltage thermostat.
If anyone is interested, I installed them yesterday and they work perfectly. Took around 10 minutes from the installation to the config in ha. Perfect for anyone looking for line voltage thermostat.
Hello all
I use this too, works great.
Just wondering… this unit has different stages, from the manual:
Heating Power Indicator
Whenever the thermostat is actively heating the room, the heating status graph will display the
heating percentage.
No bar: 0%
1 bar: 1-25%
2 bars: 26-50%
3 bars: 51-75%
4 bars: 76-100%
Does anyone know if this info can be obtained via attributes? I’d like to try to calculate power consumption.
Thanks!
I have just installed a stelpro stzw402+ and have it connected to my Zwave network, reading temperature. I can set a target temperature, but that does not change the set point displayed on the unit itself. Also the climate node displays:
Should one of these be the target temperature?
thanks
John Phillips
How did you manage to make them work?
I add the node. Everything show up with two entities.
But I don’t seem to be able to set the temperature by z-wave.
What him I missing?
Thanks!
How did you manage to make this work? Please help here.
Made it works:
