Step by step guide: Change icon based on state
I also try to changed icon when the state is changed, but in a Entities Card Configuration
i try several examples but nothing works
does somebody know the solution?
type: entities
entities:
  - entity: binary_sensor.shelly_2_5_volume_wtw_overheating
  - entity: sensor.shelly_2_5_volume_wtw_voltage
  - entity: sensor.shelly_2_5_volume_wtw_device_temperature
  - entity: input_number.wtw_luchtvolume
    icon: mdi:fan-speed-1
  - entity: cover.shelly_2_5_volume_wtw
title: WTW
show_header_toggle: false
state_color: true
“input_number.wtw_luchtvolume”" is an helper with standard mdi:fan icon
and should be :
0.0 = mdi:fan
1.0 = mdi:fan-speed-1
2.0 = mdi:fan-speed-2
I think you only can change an icon at the properties popup of an entity as shown here (my read-contact):
Or when you created a custom sensor you can use the icon_template
Regards
what if it’s an existing sensor? I keep getting an error.
It depends a bit on your use case. If you want to give a sensor 3 states it might need to be a different sensor type (typically those sensors are binary sensors that can only have state on/off). So if you want to have > 2 states you need a different sensor type thus a new one.
I know we could go down a rabbit hole with this one. But the state the device reports may only be 2 fundamentally. But the system interface will then have a number of others including unavailable which needs to be taken care of in automations / blueprints. Additionally there is also the ability to build using other HA sensors such as Template, Bayesian, Threshold, Trend add with the ability to add command line and formulas to the math. My point is that even though the devices may only report the basic 2 Binary states there is the ability with Zigbee and Zwave to drill down to the actual device interfaces and obtain other data, as well as apply other math to the change states.
Hi Sjoer,
I am glad you got the custom value and icon template working for binary sensors. From what I understand one creates a new/dummy sensor that “inherits” certain values from your main sensor and those values such as color, icon, state value output can be amended through the template.
What I struggle with is the actual hierarchy/structure of how to put. this into the customisation.yaml file.
Here is my top line file including the part with your code.
default_config:
http:
  use_x_forwarded_for: true
  trusted_proxies:
    - 10.21.0.0/16
  - platform: bitcoin
    display_options:
      - exchangerate
      - trade_volume_btc
      - hash_rate
      - market_price_usd
homeassistant:
  binary_sensor:
      sensors:
        frontdoor_hook:
          device_class: opening
          friendly_name: "front-door hook"
          value_template: >-
            {% if is_state("binary_sensor.status_main_entrance_gate", "on") %}
              off
            {% else %}
              on
            {% endif %}
          icon_template: >-
              mdi:lock-outline
            {% else %}
              mdi:lock-open-variant-outline
            {% endif %}
  customize:
    binary_sensor.status_ufh_circulation_pump:
      friendly_name: "G0294 UFH Circulation Pump"
      icon: mdi:kettle
  packages:
    pack_borehole:
      knx:
        switch:
          - name: "G0399 Borehole Pump"
            address: "7/3/14"
            state_address: "7/3/15"
I am getting this error: " extra keys not allowed @ data[‘binary_sensor’]" which I don’t understand.
Any chance to please point me in the right direction?
I am on container installation version 2023.02 which comes as part of the umbrel.com server.
Martin
binary_sensor: should be on the same level as home_assistant:, not a child of it.
Better yet, you’d use the more current config schema
template:
  - binary_sensor:
See https://www.home-assistant.io/integrations/template/#state-based-template-binary-sensors-buttons-numbers-selects-and-sensors
Hi Matthias,
Thanks for your help, much appreciated. I must say I struggle a bit (new top HA) when combining information from the main documentation then mixed with community suggestions that (here and there) date back a few years. Obviously schemas and concepts have changed/improved over the years and it was good to now understand how templates in relationship to sensors work.
Here is the code that now works - creating two sensors (not to be mixed up with binary_sensors that are the triggers) that show correct state value and icon. The code is in configuration.yaml and not nested within the homeassistant: object.
template:
  - sensor:
      #Main Garage Door
      - name: "Status Main Garage Door"
        state: >
          {% if is_state("binary_sensor.status_garage_roll_gate", "on") %}
            closed
          {% else %}
            open
          {% endif %}
        icon: >
            mdi:garage-variant-lock
          {% else %}
            mdi:garage-open-variant
          {% endif %}
      #Main Entrance Gate
      - name: "Status Main Entrance Gate"
        state: >
          {% if is_state("binary_sensor. status_main_entrance_gate", "on") %}
            closed
          {% else %}
            open
          {% endif %}
        icon: >
            mdi:gate
          {% else %}
            mdi:gate-arrow-right
          {% endif %}
homeassistant:
  customize:
    pack_security:
      knx:
        binary_sensor:
            # Closed = 1, Open = 0
            state_address: "9/7/3"
          - name: "Status Garage Roll Gate"
            state_address: "9/7/6"
        button:
          - name: "Button Main Gate"
            address: "9/2/0"
          - name: "Button Main Garage"
            address: "9/2/1"
          - name: "Button Guest House Gate"
            address: "9/2/2"
Again, thanks for your help.
Rgds
Martin
This is very similar to my code for my garage doors, but I also changed the colors. I’m using custom-ui in HACS and added this to my customize.yaml file
cover.2_car_garage_door_opener:
    friendly_name: '2-Car Garage Door Opener'
    templates:
      icon: >
        if (state == 'open') return 'mdi:garage-open-variant';
        if (state == 'closed') return 'mdi:garage-variant';
        return 'mdi:garage-alert-variant';
      icon_color: >
        if (state == 'open') return 'red';
        if (state == 'closed') return 'green';
        return 'yellow';
cover.1_car_garage_door_opener:
    friendly_name: '1-Car Garage Door Opener'
    templates:
      icon: >
        if (state == 'open') return 'mdi:garage-open';
        if (state == 'closed') return 'mdi:garage';
        return 'mdi:garage-alert';
      icon_color: >
        return 'yellow';
Thanks for this, Helped me to change text on a single mushroom card chip to peak/off peak/shoulder to show what electricity i’m currently using!
I came up with a solution to control garage doors and show the open/close status with icons. I posted the guide here: Garage Door Openers/Sensors Combo Card - Community Guides - Home Assistant Community (home-assistant.io)
@matthijsberg I got the icon to change, but the state is always Off.
I tried the following to change the left balcony icons without making a new sensor:
(Didn’t work)
# Change Icons - Attempt
homeassistant:
  customize:
    binary_sensor.left_balcony_door_contact:
      templates:
        icon: >
          if (state == 'on') return 'mdi:door-sliding-open';
          return 'mdi:door-sliding';
      # icon_template: >
      # {{'mdi:door-sliding-open' if is_state('binary_sensor.right_balcony_door_contact','on') else 'mdi:door-sliding'}};
    # binary_sensor.right_balcony_door_contact:
I tried making a new binary sensor for the right balcony door. The icon works, but the value/state doesn't.
# Binary Sensors
binary_sensor:
    sensors:
      right_balcony_door_contact_template:
        friendly_name: Right Balcony Door Contact Template
        value_template: >-
          {%- if is_state("binary_sensor.right_balcony_door_contact", "on")  -%}
            Open
          {%- else -%}
            Closed
          {%- endif %}
        icon_template: "mdi:door-sliding{{ '-open' if is_state('binary_sensor.right_balcony_door_contact','on') else '' }}"
For the pictures below, the top two sensors are from the devices themselves. The bottom one is the binary sensor I created. Thanks!
I am trying similar thing but I don’t have lovelace installed.
I am trying to change state of my wifi icon , based on the signal strength of the wifi_signal.
I have added following to the yaml file
- platform: wifi_signal
    update_interval: 5s
    entity_category: "diagnostic"
  - platform: copy
    source_id: wifi_signal_db
    name: "Wifi Signal %"
    filters:
    - lambda: return min(max(2 * (x + 100.0), 0.0), 100.0);
    icon: >-
          {% if sensor.room1_wifi_signal >= '52' %} mdi:wifi-strength-4
          {% elif sensor.room1_wifi_signal < '52' %} mdi:wifi-strength-3
          {% endif %}
    unit_of_measurement: "%"
I am gettting following errors
Icons must match the format "[icon pack]:[icon]", e.g. "mdi:home-assistant".
As adanced users here can see, I am new to home assistant, can somebody guide me in solvoing the problem ?
Thanks and Regards
Hi, addind to the above, seeing a post i have modifief the yaml file of my esp32 to following, but the icon is not changing dynamically, it changes only once.
Can any body guide , what is the problem in my yaml code.
esphome:
  friendly_name: room1
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "KKaUZtsqqkZuzECMn7rWXmSyNaj/NCfQrwJw6oN/2Bk="
ota:
i2c:
  sda: 21
  scl: 22
  scan: true
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Esphome-Web-Cb77A0"
    password: "dqW2cJNSPWHg"
captive_portal:
  - platform: sht4x
    precision: Med
    heater_time: Short
    update_interval: 5s
    temperature:
      accuracy_decimals: 3
    humidity:
      name: "Relative Humidity"
    update_interval: 5s
  - platform: copy
    filters:
    - lambda: >
            int y=min(max(2 * (x + 100.0), 0.0), 100.0);
            if(y>=85) id(room1_db).set_icon("mdi:wifi-strength-4");
            else if (y>65) id(room1_db).set_icon("mdi:wifi-strength-3");
            else if (y>30) id(room1_db).set_icon("mdi:wifi-strength-2");
            else if (y>10) id(room1_db).set_icon("mdi:wifi-strength-1");
            else id(room1_db).set_icon("mdi:wifi-strength-off-outline");
            return y;
Thanks and Regards,
i got mine like this now:
