Stepper Motor, ESPHome
Hi Guys,
I’m trying to implement a stepper motor in esphome but something must have changed recently regarding inverting a pin.
If I try to upload the sketch, it fails. I check the What Went Wrong, and it keeps telling me the following;
mapping values are not allowed here in "/config/esphome/curtain-steppertest-1.yaml", line 61, column 14
Line 61 is the following;
inverted: True
I can’t understand why this isn’t accepted. Heres the full sketch;
esphome:
  friendly_name: Curtain Stepper Test 1
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "xxxxxx"
  #services:
   # - service: shaft_target
ota:
  - platform: esphome
    password: "xxxxxx"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Curtain-Stepper-test-1"
    password: "xxxxxx"
    services:
      - service: position
        variables:
          target: int
        then:
          - stepper.set_target:
            target: !lambda "return target"
captive_portal:
number:
    optimistic: True
    min_value: 0
    max_value: 2000
    step: 1
    on_value:
      then:
            target: !lambda 'return x;'
stepper:
  - platform: a4988
    dir_pin: 17
     inverted: True
    step_pin: 21
    max_speed: 1000 steps/s
    sleep_pin: 22
     inverted: True
    acceleration: 800
    deceleration: 800
I had a similar experience with a serial setup.
It worked with both pins inverted and both pins not inverted.
But not with just one pin inverted.
That is highly illegal YAML. Look at the docs again for proper form.
Hi Guys,
Thank you for your replies. Im very grateful.
I’ve edited the sketch, and it will now compile and upload, but I get nothing from the motor if I move the slider.
I wondering if it’s my wiring setup or setting on the driver I have?
Heres the current sketch;
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
api:
  encryption:
    key: "xxxxx"
ota:
  - platform: esphome
    password: "xxxxx"
wifi:
  ap:
    password: "xxxxx"
captive_portal:
number:
    optimistic: True
    mode: SLIDER
    min_value: 0
    max_value: 100
    step: 1
    on_value:
      then:
stepper:
  - platform: a4988
    dir_pin:
      number: GPIO17
      inverted: True
    step_pin: GPIO21
    max_speed: 250 steps/s
    sleep_pin:
      number: GPIO22
      inverted: True
    acceleration: 800
    deceleration: 800
This is the driver I have and the Nema 23 motor.
https://www.aliexpress.com/item/1005004822801078.html?spm=a2g0o.order_list.order_list_main.35.b9b61802Uy8FXE
https://www.omc-stepperonline.com/nema-23-stepper-motor-2-4nm-339-79oz-in-4a-57x57x82mm-8mm-shaft-4-wires-23hs32-4004s
I have a 24v 600w PSU connected to the driver COM and VM (- & +).
The ESP32 to Driver have the following connections;
GPIO 17 to Dir + on the driver
GPIO 21 to Stp + on the driver
GPIO 22 to En + on the driver
I also have a Gnd wire from the ESP to the Negative on the PSU (same terminal as the COM on Driver).
Should my sketch theoretically work, or is it my wiring?
Check the datasheet for that interface board… you may not need to invert the “Sleep Pin”
You also need to connect all three - to GND
… A quick Google-ing later:
Indeed the Enable Pin on your board is “Active High” - So you should not need to invert it
@3ATIVE @Karosm @Rudd-O @WallyR
Thank you guys for your replies. I’m most grateful.
I’m waiting for the retailer to reply with the data sheet.
So Dir -(negative), Stp- (negative), and En - (negative), all need connecting to ESP32 - Gnd.
@3ATIVE just spotted your googled reply, Ill give that a go.
@3ATIVE before you loose the google info, where exactly did you find that information?
I’ve found very little information on this driver board, I’ve even got the seller trying to tell that it can use Stallguard which I think is a load of dogs gonads to be honest.
Which should be common ground with driver board.
Alternatively you can connect +pins to 3.3V and -pins to Esp gpio pins.
@Karosm @3ATIVE
Solved By @Karosm & @3ATIVE in the posts above.
Thank You Guys.
I’m now up and running, or should I say rotating.
You were both correct with your replies.
As I can’t select both your posts as solutions, Ill click it on this post.
I needed En to be High and not Low, and i needed a Gnd from the ESP to Dri-, Stp- and En- (- Negative).
I can now tinker away and start experimenting.
Thank you again.
Dizzwold.
Excellent, that’s great news. So happy I (we) were able to help.
  • Have fun :partying_face:
