I’m trying to use a stepper motor to create a twinkling effect on some fiber optic star ceiling.
I would like to set a fixed speed for the stepper motor, but the “stepper.set_speed” action does not seem to work properly.
I followed the example from the stepper documentation, and the stepper motor works fine with the “stepper.set_target” action.
My problem is that when i switch to “stepper.set_speed”, nothing happens. No action using a scope either.
My code is as follows:
ESPHOME config:
api:
services:
- service: control_stepper
variables:
speed: float
then:
- logger.log: "Speed updated"
- stepper.set_speed:
speed: !lambda 'return speed;'
# Stepper motor
stepper:
- platform: a4988
step_pin: D5
dir_pin: D6
sleep_pin: D7
max_speed: 250 steps/s
acceleration: inf
deceleration: inf
Home Automation config:
# Add a slider control to Home Assistant to set an integer value
input_number:
stepper_control:
initial: 0
min: -100
max: 100
step: 1
mode: slider
# Do something when the slider changes
automation:
- alias: Write Stepper Value to ESP
platform: state
entity_id: input_number.stepper_control
# Replace livingroom with the name you gave the ESP
- service: esphome.stars_control_stepper
data_template:
speed: '{{ trigger.to_state.state | float }}'
Anyone got any idea of why the set_speed action does not work?
ps: I also wonder how i could print the value of the variable passed to the api in the logger.log function.
Hi Jan-Erik,
DId you solved this?
I’m actually doing the same thing with the star optics
Hi!
I finally got it working, and i would like to share my solution to the problem.
My setup is as follows:
WT32-ETHO1 with temperature sensors (1-wire / Dallas), one stepper motor driver (A4988) and RGBW leds controlled by PWM.
EspHome config
Starlight.yaml
esphome:
platform: ESP32
board: esp-wrover-kit
ethernet:
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO0_IN
phy_addr: 1
power_pin: GPIO16
# Optional manual IP
manual_ip:
static_ip: 10.0.3.002
gateway: 10.0.0.1
subnet: 255.255.252.0
# Enable logging
logger:
level: VERBOSE
# Web Server
web_server:
port: 80
# Globals
globals:
- id: stepper_speed
type: float
restore_value: no
initial_value: '0'
# Enable Home Assistant API
api:
password: <top-secret>
services:
variables:
speed: float
then:
- globals.set:
value: !lambda 'return speed;'
- logger.log:
format: "New speed= %.1f"
args: ['id(stepper_speed)']
- stepper.set_target:
target: !lambda |-
if (id(stepper_speed) > 0) {
return 10000000.0;
else if (id(stepper_speed) < 0) {
return -10000000.0;
else {return 0.0;}
ota:
# Example configuration entry
dallas:
- pin: GPIO5
# Individual sensors
- platform: dallas
address: 0x36021833C94CFF28
- platform: dallas
address: 0xDE031850B7B1FF28
name: "Temperatur DC-DC converter"
- platform: dallas
address: 0xBA021833CBABFF28
name: "Temperatur StepperDriver"
# Stepper motor
stepper:
- platform: a4988
step_pin: GPIO4
dir_pin: GPIO32
max_speed: 500 steps/s
# Optional:
sleep_pin: GPIO2
acceleration: inf
deceleration: inf
light:
- platform: rgbw
effects:
- flicker:
- flicker:
name: Flicker Effect With Custom Values
alpha: 95%
intensity: 1.5%
- random:
- random:
name: Random Effect With Custom Values
transition_length: 5s
update_interval: 7s
red: output_red
green: output_green
blue: output_blue
white: output_white
# Example output entry
output:
- platform: ledc
pin:
number: GPIO15
max_power: 100%
- platform: ledc
pin:
number: GPIO12
max_power: 100%
- platform: ledc
pin:
number: GPIO33
max_power: 100%
- platform: ledc
pin:
number: GPIO14
max_power: 100%
Home Automation
Configuration.yaml
input_number:
stepper_control:
initial: 0.0
min: 0.0
max: 500.0
step: 10.0
mode: slider
Automation.yaml
- alias: Write Stepper Value to WT32
platform: state
data_template:
speed: '{{ trigger.to_state.state | float}}'
On your dashboard you can now create a new Entity (slider) and connect it to the “input_number.stepper_control”. When this slider is changing value, it will trigger a service that sends the speed setpoint to the ESPhome controller.
I hope this may be helpfull to someone!
I have not had time to look into this project until now, but I found a solution as stated bellow. I hope this helps
