Hi there,
I am using esphome in order to drive a stepper motor that drives a worm gearbox. That for I need ~1000rpm. The hardware is easily capable of that speed. After power up of my esp32 I am able to drive the stepper at full speed for about 3-4 seconds. afterwards speed reduces tremendously and stays constant. I have the feeling, that as soon as the esphome connects to wifi, the processor is clocked with other tasks and cannot run the step pin at these high speeds any longer. Did anybody have the same problem or has a solution for that?
I am using a tmc2208 stepper driver which is wired as of TMC2208 ESPHOME quiet curtains - YouTube.
used board is: S2 mini — WEMOS documentation
the code works flawlessly and the stepper starts on first button click and ends on second button click. Only the speed is awful slow.
my code:
esphome:
friendly_name: test_board
esp32:
board: lolin_s2_mini
variant: esp32s2
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "xxx"
ota:
password: "xxx"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Test-Board Fallback Hotspot"
password: "xxx"
captive_portal:
stepper:
- platform: a4988
dir_pin:
number: GPIO38
inverted: True
step_pin: GPIO36
sleep_pin:
number: GPIO17
inverted: True
max_speed: 200000 steps/s # Set the speed of the motor for 1000 rpm
acceleration: inf
deceleration: inf
globals:
- id: my_stepper_move
type: bool
restore_value: True
initial_value: '0'
binary_sensor:
- platform: gpio
pin:
number: GPIO21
mode: INPUT_PULLUP
inverted: True
internal: True
on_click:
- min_length: 50ms
max_length: 500ms
then:
- if:
condition:
- lambda: 'return id(my_stepper_move) == 0;'
then:
- globals.set:
value: '1'
- script.execute: move_up
else:
- globals.set:
value: '0'
- script.execute: stop
script:
- id: move_up
then:
- stepper.set_target:
target: !lambda return id(my_stepper).current_position-200000;
- id: stop
then:
target: !lambda return id(my_stepper).current_position;
