Stereo Amp for Single Room, Controllable w HA
Hello, I am wondering if anybody has found a good solution for a stereo amplifier that can be controlled with HA, and ideally with AirPlay integrated. All I need is a pair of powered ~50-100W outputs.
I have a big multichannel multi zone Onkyo Amp for my main floor, and it works great - I am very happy with the HA integration and ability to control every function of the amp with HA.
Upstairs, I’d like to add stereo audio (with passive speakers) to one room, and it’s not convenient to run wires all the way to the Onkyo, so I was thinking of just adding a simple stereo amp for that room. However, the only options I’ve seen so far are either cheap boxes with manual knob controls, or full receivers that are basically equivalent to my existing Onkyo and are overkill.
Thank you for any recommendations!
Bluesound PowerNode maybe?
I’ll check that out, thanks. I might have just answered my own question- after posting this is kept searching and stumbled upon this which looks promising. Does anybody here have any experience using this with HA? I’m not interested in using their proprietary app.
Apparently that amp works very well with this core integration:
Source: https://www.reddit.com/r/homeassistant/comments/10h5vj3/am_i_missing_something_with_arylic_a50/ and then read the depreciation notice here (because it is included in core now): GitHub - nagyrobi/home-assistant-custom-components-linkplay: LinkPlay based media devices integration for Home Assistant.
I wish I’d known about this before shelling out for a Yamaha WXA-50 for my workshop. The Yamaha also works very well with Home Assistant but is 1.5x the price.
Also beware both the Acrylic and Yamaha amps are only Airplay 1. Not a big deal but for me it means I can’t group my Yamaha RX-V685 amps with the WXA-50 using Airplay, however…
If you get the Acrylic amp Linkplay does support multi-room playing.
Thanks for flagging no Airplay 2. I usually use Spotify Connect so I think I’d be fine with Airplay 1 for the occasional times I’d need airplay. Yes, I saw that the LinkPlay integration is now part of HA core, so that sounds like it should work seamlessly!
Btw, the Powernode has AirPlay 2 and BluOS has HA integration too. Yes, it is not that cheap, but even here the global rule counts: You get, what you pay for :wink:
True, though in this case it’s not slightly more expensive, it’s ~6x more expensive. My use case is for some basic speakers in an accessory room, so I think I’ll try the Arylic first, it seems to have a lot of good reviews and very good HA integration
That little acrylic amp is absolutely alright for some basic speakers. I had a bluesound powernode amp and replaced it with the wiim amp (also linkplay/acrylic, same platform) out of curiosity when it was released because of the reviews. For me it’s better in almost all areas while costing less than half.
But beware, the official linkplay integration is quite new. I think grouping speakers isn’t possible with the official integration yet, for example.
Update - I’ve read some reviews that the Arylic has relatively poor sound quality. I don’t know how much stock to put in those reviews, but I’m also looking at the Wiim Amp WiiM Amp | Versatile Streaming Amplifier: Stream Elegance, Amplify Brilliance
I am also interested in integrated amplifier that I can control with HA:
  • select input on the fly
  • change volume
  • set volume
In integrated amplifier I would like to see:
  • usb port for PC connection
  • optical port, maybe 2
  • Ethernet port for HA control (I don’t want workarounds like IR-blasters)
  • Bluetooth is nice to have
  • I am fine without HDMI and streaming services and Google/Alexa voice assistants
Also no sleep/standby mode. I want to start playing songs instantly. And minimum power consumption.
On paper Arylic H50 sounds good. But I read that it’s not very easy to integrate it with HA. Also not good reviews:
Have you found a good integrated amplifier for HA?
I ended up getting the WiiM Amp and am very happy with it so far
Does it have sleep/standby mode? Any noise/coil whine? How is power consuption?
I see it has USB port but only for external usb devices unfortunately.
How did you integrate it to HA? What HA integration is used? What control options available?
Does it work with HA out of the box or you need to setup it with the app first?
Yes it seems to sleep very well. I haven’t noticed any noise, but maybe I’m not that discerning? All the reviews I read seemed to think that it performed pretty well in terms of audio quality and I don’t disagree
Now that I think about it, it’s been working so well just via airplay and Spotify connect, I realize I haven’t yet integrated it with HA. But I am pretty sure that it can be integrated with HA, just haven’t gotten there yet
I mean can it play song instantly without any delay from stand-by mode?
Please keep us updated when you setup it with HA :slightly_smiling_face:
Hmm I don’t know about instantly, but within a second or two I think? But that’s more the airplay connection time I think. If it was already connected to a source I think it would start faster
I think it would be very important for notifications and announcements from HA. Also Assist responses in the future.
This is all useful to read but I feel that it misses the main point about having an amp that has a good HA integration: it should only amplify well! HA can stream music via Music Assistant and it now has excellent voice control over Voice PE.
So all we need is an amp with a proper integration, connectors for passive speakers and maaaaaybe a volume knob. This should not cost £400 and include a number of unnecessary options.
I am having a hard time finding any to be honest. Help would be much appreciated.
volume knob and physical buttons or knob to switch inputs is a must
Older thread, but I’ve been thinking about this same problem for years now. And it was one of top results when searching for “home assistant amplifier.”
I agree these little network amps are vastly overpriced for what they are.
So, in my case, we are running a sort of “DIY Sonos” multi-room audio system based on Raspberry Pis + HiFiBerry AMP hats, Mopidy, and Snapcast, which works very well for our needs, and is pretty economical and flexible (can use any old regular speakers you already have, etc.).
Recently I’ve started to think about buying any decent name brand old school receiver (Marantz, Onkyo, Yamaha, etc.; anything with an HA integration, and recent enough to support network control) off eBay. They seem to have fallen out of fashion and therefore are available inexpensively these days.
Anyway, hopefully that gives a couple different options to consider, depending on requirements.
