I already have Pushover notifications on HA but also want to add email notification. Hoiwever when I add SMTP I get :
Error mean you have a duplication" notify" in your config yaml. You can only have one. You can add the smtp to the existing notify setting.
notify:
- platform: existing one
- platform: smtp
sender: "YOUR_SENDER"
recipient: "YOUR_RECIPIENT"
Thanks !!! I try that now,
No success (for security I deleted API/KEY from picture
It’s a syntax error, you need a dash with a new service.
it’s complaining about your space/tab, can you paste your code. yaml is space sensitive.
Thanks so much for taking the time
try putting a space before the dash.
you can also test your code with a yaml validator https://jsonformatter.org/yaml-validator
I am on my way out but will try later. THANKS
