I updated from 0.36.1 to 0.38.2 in Virtualenv. But when I do a reboot the old version is still launched. So I stopped 0.36.1 and started hass in the Virtualenv, it starts 0.38.2. Very strange. So it seems that when I start it with sudo systemctl start home-assistant.service, it start the old version. Can I change this to start the new version?
I am having the same issue while upgrading to 0.53 from 0.45.
It seems like my upgrade worked and I have 0.53 installed in my virtualenv ,
but when I start HA, it still shows 0.45
However, your solution does not seem to work.
Also the directory: /srv/homeassistant/homeassistant_venv/bin does not exist.
Can you explain what this line: ExecStartPre=source /srv/homeassistant/homeassistant_venv/bin
supposed to do and if you know what need to change now for version 0.53
Thank you very much for helping…
Indeed, I found two different versions: one in virtualenv and one outside. I will be upgrading to HAAS.IO soon, so I just used the one outside of virtualenv and that worked for me.
