Still SLL problems after adding “ssl_profile: intermediate”
I have had SSL errors for a while and have added the below to configuration.yaml, but it does not help. I don not have any problems, but it makes my log file grows rapidly.
http:
This was recommended at github
https://github.com/home-assistant/home-assistant/pull/15957.
I’m running 0.76.1 on hassos 1.9 with DuckDNS add-on.
Should I try “old” instead of intermediate or do I do something wrong?
2018-08-21 06:06:34 ERROR (MainThread) [homeassistant.core] Error doing job: SSL handshake failed
  File "uvloop/handles/stream.pyx", line 609, in uvloop.loop.UVStream._on_eof
  File "uvloop/sslproto.pyx", line 171, in uvloop.loop._SSLPipe.feed_ssldata
  File "/usr/local/lib/python3.6/ssl.py", line 689, in do_handshake
    self._sslobj.do_handshake()
ssl.SSLError: [SSL: WRONG_VERSION_NUMBER] wrong version number (_ssl.c:841)
2018-08-21 06:06:34 ERROR (MainThread) [homeassistant.core] Error doing job: SSL error errno:1 reason: WRONG_VERSION_NUMBER
  File "uvloop/sslproto.pyx", line 504, in uvloop.loop.SSLProtocol.data_received
  File "uvloop/sslproto.pyx", line 204, in uvloop.loop._SSLPipe.feed_ssldata
2018-08-21 06:07:00 ERROR (SyncWorker_17) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
2018-08-21 06:09:04 ERROR (SyncWorker_15) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
Try it out and post the result :wink:
I will do that!
Ok, i tested with “old” but then SSL stopped working for me.
