because of various errors in the logs, maybe related to local network settings, please let me ask about the auth provider trusted network setting.
docs show 192.168.0.0/24
My router is at 192.168.1.1 though, but using 192.168.1.1/24 results in
2019-06-03 12:15:08 ERROR (MainThread) [homeassistant.auth.providers] Invalid configuration for auth provider trusted_networks: not a valid value @ data['trusted_networks'][1]. Got '192.168.1.1/24'
2019-06-03 12:15:10 ERROR (MainThread) [homeassistant.config] Invalid config for [homeassistant]: not a valid value @ data['trusted_networks'][1]. Got None. (See /config/configuration.yaml, line 1).
tried to google this, but all info about the subnet masks don’t help me understanding what the notation does in fact, and what I should be using in my case.
HA makes it clear this is so obviously wrong ;-( I might be able to only use 192.168.1.1, and did so before, but that gave me auto lockouts and ip-bans for devices on my own network…
So, question is, why is the correct setting in the trusted network section? Would appreciate any help.
Would it be 192.168.1.0/24 meaning all addresses from 192.168.1.0 to 192.168.1.255?
secondly, could this be related:
2019-06-03 12:33:30 ERROR (MainThread) [homeassistant.setup] Error during setup of component asuswrt
File "/usr/local/lib/python3.7/site-packages/homeassistant/setup.py", line 153, in _async_setup_component
hass, processed_config)
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/asuswrt/__init__.py", line 55, in async_setup
await api.connection.async_connect()
File "/usr/local/lib/python3.7/site-packages/aioasuswrt/connection.py", line 72, in async_connect
self._client = await asyncssh.connect(self._host, **kwargs)
File "/usr/local/lib/python3.7/site-packages/asyncssh/misc.py", line 182, in __await__
return (yield from self._coro)
File "/usr/local/lib/python3.7/site-packages/asyncssh/connection.py", line 5451, in connect
conn, _ = yield from create_connection(None, host, port, **kwargs)
File "/usr/local/lib/python3.7/site-packages/asyncssh/connection.py", line 5107, in create_connection
yield from auth_waiter
asyncssh.misc.DisconnectError: Disconnect Error: Connection lost
this is the tinydtls.py error I see popping up again, killing my Ikea Tradfri setup.
2019-06-03 12:35:08 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/local/lib/python3.7/site-packages/aiocoap/transports/tinydtls.py", line 157, in _run
yield from self._connecting
concurrent.futures._base.CancelledError
File "/usr/local/lib/python3.7/site-packages/aiocoap/transports/tinydtls.py", line 169, in _run
self.coaptransport.new_error_callback(-1, self)
File "/usr/local/lib/python3.7/site-packages/aiocoap/protocol.py", line 203, in _dispatch_error
for key, (monitor, cancellable_timeout) in self._active_exchanges.items():
AttributeError: 'NoneType' object has no attribute 'items'
Thanks!
