Hello
First time messaging after learning and lurking quite a bit. Please be patient with any mistakes made in creating this post.
I had created a basic presence mode to help my ecobee go into away mode more reliably and quickly. I had it working well with the set_away_mode “on, off” previously. Using this did not pass an argument for holds, so that was left to the original scheduling with the ecobee (the desired outcome)
With the new version, I read the documentation and change set_away_mode to set_preset_mode and sent the instruction
{"preset_mode":"home"}
or
{"preset_mode":"away"}
which does work, but it now also passes an argument for setting hold times. This is not desired, because it interferes with it going into vacation mode, or more importantly, sleep mode at night (programmed into the scheduler in the ecobee.
Doing more research, I found that I could add a note to my configuration.yaml under the ecobee setting that said:
ecobee:
api_key: mykey
hold_temp: false
This however does not get rid of the hold, it only changes the hold from indefinite, to until next state change.
My question is, how can I revert back to the old behavior where it didn’t pass a hold argument at all? Is there an set_hold_mode that I can pass with my set_preset_mode to tell it to not hold at all?
Thanks for your time and patience. I"m happy to upload any other information you may need.
Marsh
I noticed that if I use climate.set_preset_mode home it holds until my next ecobee scheduled event, but if I use climate.set_preset_mode away it appears to be indefinite (I haven’t fully tested that yet). This actually works fine for me, though. I set it to away when I leave home, then I use this when I arrive home, which switches it back to the normal ecobee schedule:
I deleted a previous message. Your work around is great actually. I ran the standard set_preset_mode to home. Then I added a 5 second delay and ran your resume code. That took the hold off, and left it in home.
Thank you for the workaround.
Funny, I received your original post in an email and was thinking “I am doing exactly what he is describing.” So yeah, I also want ecobee to set sleep mode etc. on its own. I’m just forcing it into away mode when I leave the house, and then forcing it back into its native schedule when I return. Glad it’s working for you now!
Your reply sounds great, but unfortunately doesn’t work for me. I am trying to figure out how to set the away mode, AND be able to revert to the schedule while I’m away. Because the away mode is an indefinite hold, my house won’t be preheated, or even begin heating, until I arrive home, and/or that away hold is turned off. I could programmatically turn off, IF I knew what the current ecobee programmed state was, but, that functionality/information seems to have been removed. It worked perfectly for me before 0.96 and 0.97. I am very disappointing in the recent changes. The best idea I can come up with, is to create a custom climate mode simulating an away mode. Anyone else have any ideas?
I’m making it work, but I do agree that it worked perfectly before. I think not having the prewarm function is really going to suck in this new england winter.
I’m somewhat new to HA, so I don’t know if there is someone to message, or do we not get any say.
I submitted a GitHub issue report with the author. We’ll see what kind of a response I get. A work-around, might be to create an additional climate mode, set up the same as your regular away mode, and then call that climate mode in your script, instead of the default away mode. I haven’t tested that theory yet.
This is what I found with my ecobee, hopefully this will give you what you need:
results in persistent away hold, which survives changes in the ecobee program schedule; whereas
{"preset_mode":"Away"}
puts the thermostat into away hold, but only until the next schedule change. This discovery was purely by luck - my ecobee reports three states in Developer Tools > States:
preset_modes: Home,Away,Sleep
and I just used copy/paste in my coding to test the various states, which resulted in non-persistent behaviour for all three (which was not what I was expecting! ).
What version of Hass.io are you running. I tested mind, and the capital “A” did nothing (no hold was set at all), only the lowercase “a” sets the persistent away mode. Mine is v. 0.97.
@c.dawg
I’m running HomeAssistant 0.97.1 in a docker container (image pulled from homeassistant/home-assistant:latest) on Ubuntu 18.04 LTS. To double check my results I just created a test schedule on my ecobee as follows:
Ugh … there must be something different between your setup, and my Hass.io, because using the capital “A” doesn’t set any kind of a hold on my Ecobee at all. I am very disappointed with the recent changes. I used to have full interaction with my Ecobee, and now it seems very restricted.
I’m guessing it’s an operating system or python variance, rather than Home Assistant itself. But it might be different incarnations of ecobee, I guess. Here’s my system info, as of today, perhaps it helps you determine what’s different between mine and yours:
According to the notes, it looks like they may have reverted the behavior in .98. I"m going to wait for a couple of days to see if there is a point release immediately, and then install. Will update on here after I do.
I’ve updated, and it does not seem to have changed the hold state.
Something else I’ve found is that if I set the ecobee to off, and turn it back on,it will default to Heat instead of the last state that it was in.
I noticed that one of my automations was not working, and finally today tracked it back to a new case sensitivity issue with my ecobee. In the below condition, the “A” in Away was previously lowercase. It worked fine until a recent HA update. Not it only works with a capital A.
My workaround for preset_mode: Away being permanent was to create a custom preset mode called “Economy” that acts as a temporary away mode. Of note, you can now enter custom comfort settings by name, rather than “smart1, smart2, etc.”
Sorry to drag out an old thread, but this seems about as good a place as any to mention this:
I’m also seeing the same behavior with holds on Away. If I use a capital A in Away, it holds until the next scheduled change, but a lower case a in away holds indefinitely.
In my case, I’m trying to setup an ExtendedAway mode, and DO want it to persist past the schedules, but can’t make it. It feels like a better way to deal with this would be to have a flag we can set when we call climate.set_preset_mode. Other smart home platforms I’ve used let you decide when you call the mode.
I trolled through climate.py a bit trying to see if I could figure it out, but gave up.
Fast follow-up here with my solution. Far from how Ecobee was intended to be used, but I’ve been able to set any mode I want, and make it persist, by setting bespoke vacations.
Mostly I was using these extended aways for multi-day away periods, like a weekend away, or an overnight business trip, so this isn’t really that far from what I wanted. I use the ecobee.create_vacation method without a start or end time, and it automatically sets for 14 days. My programming already predicted my return(proximity), so at the right time I simply remove that vacation with delete_vacation.
