I don’t have that sensor, but there should be a configuration choice in OZCP when you click on the device. Any configuration that Open Zwave knows about the device would be listed there. Updating the XML doesn’t send the command to the device.
You might try the zwave.set_config_parameter via the services dev tool. Here’s some discussion on the subject:
