Hi all, struggling to find a solution & I’m new to automation in HA. My motion lights work great, however, if I then turn the light on manually which is set to 100% (auto is 5%), the lights go off after motion changes from detected to clear.
I have seen reference to a boolean, but unsure how to set this helper up and intergrate?
{{ input_boolean.use_sensor_state == 'on' and binary_sensor.motion_sensor == 'on' }}
My automation yaml is as per the below
alias: Back Porch Light
description: ""
triggers:
- trigger: state
entity_id:
- binary_sensor.ewelink_snzb_03_ias_zone
to: "on"
conditions:
- condition: or
conditions:
- condition: device
type: is_on
device_id: d3e5461b988666233ed92619bc98bddb
entity_id: 2737de9f611879e282b75d4a4771300d
domain: light
- condition: device
type: is_on
device_id: f5d0cb05bea5d74c8b3c04f0c6a77b9a
entity_id: 7ad271c865a94538f16bb610d7a6ecd8
domain: light
actions:
- alias: Turn on the light
action: light.turn_on
entity_id: light.back_porch
brightness_pct: 100
- alias: Wait until there is no motion from device
wait_for_trigger:
- trigger: state
entity_id:
to: "off"
continue_on_timeout: false
timeout:
hours: 0
minutes: 30
seconds: 0
- alias: Wait the number of seconds that has been set
delay:
hours: 0
minutes: 1
seconds: 0
milliseconds: 0
- alias: Turn off the light
action: light.turn_off
data: {}
mode: restart
max_exceeded: silent
can you give some more info?
should the motion sensor only be active when you haven’t manually turned it on?
the switch to manually turn the light on, is this a real switch or a helper?
when the light turns on, should it always be 100% brightness?
when it’s off, should it be 0% or 5%?
1.Motion sensor is always active.
2.The switch is a 4 way wireless zigbee.
3.Light turns on if the back porch motion sensor is activated to 100% & either dining room or living room light is on, I have a second automation that uses dusk to dawn and is limited to 5% for the kids in the night, if all lights are off.
So if the lights are activated by the sensor before sunrise they are 5%, I would then manually use the zigbee switch to turn it off/on to 100%.
After the automation senses no motion, all 3 lights in the yaml go off, regardless if I changed it to 100%,completing the automation.
Ohhh. I hadn’t even considered that! I had already created input_boolean helpers to set motion/presence overrides for my remotes but not yet got around to implementing that in my automations, but as I take it that shouldn’t even be necessary. Instead the motion/presence automation when it come times to turn off the light should check whether it was the one who turned it on.
Hmm. The state machine does not record “new” states which are the same as the “old” state though, so I still need to figure out how to set a “new” state when the remote is pressed but the light is already on… any hints on how to do this or suitable workarounds?
what if you use an if then else as below? (to combine both automations)
Also note that I changed the motion trigger from off to on, it was reversed in your automation.
I have connected my risco alarm motion detector so when it detects movement a light turns on.
When I manually press the light switch automation is deactivated in order to keep the light on.
After switching back to off the light, automation reactivates.
Here is how I did it:
Also, don’t forget to change entity_id: switch.sonoff_xxxxxxxxxx with your switch.
Also you need to make a boolean input_boolean.manual_button_light_saloni or whetever you call it (just rename it in automation too)
Hi Tom, this seems to refer to scenes, however I have my lights setup against automations. Would it be better if I used scenes and not automations for the result I’m trying to achieve
